Hippo-Drones
Pleb
how do you change this on a GoPro?
These are all output settings for your editing softwarehow do you change this on a GoPro?
What software are you using for the edits? Today I did a quick edit with Movie Maker, and the quality is subpar and blocky. My previous video I've used Adobe Premiere Elements and it turned out great. Both are in my channel, I'm exporting in H.264 and native resolution and FPS.
p.s. I still haven't started vlogging, need to finalize the setup, so these are just test videos for the time being. The Ski trip was with Premiere, the motorcycle vid was with Movie Maker (it sucks).
Not sure about the Hero 5's, but the 4 Blacks are at 30Mbps by default. So I don't think it's necessarily GoPros capturing footage at higher bitrates. If you enable Pro Tune, it jumps to 45Mbps, but you'll need to do a little bit of setup depending on how bright/dark it will be outside when you capture footage.One more jigsaw piece:
Footage from a Sony FDR-X3000, native 60Mbps, rendered at 60Mbps looks great.
Footage from a Drift Ghost-S, native 30Mbps, rendered at 60Mpbs does look the same as if rendered at 30Mbps.
I upload Sony 60Mbps files, which I know is overkill. But it looks a hell of a lot better than my older Drift footage. Seems to be the same for all Drift using motovloggers I'm aware of. Most of the big guys use GoPros and you can really see the difference.
Baron has 200k+ subs and sometimes his video quality is pure smudge, too.
so if I turn off protune on my 5 it'll drop to 30Mbs? My editing software will only render 1080p/60fps at a max of 30Mbs so this may be my issue, utilising protune my bitrate exceeds the ability of my editing software for MP4 filesNot sure about the Hero 5's, but the 4 Blacks are at 30Mbps by default. So I don't think it's necessarily GoPros capturing footage at higher bitrates. If you enable Pro Tune, it jumps to 45Mbps, but you'll need to do a little bit of setup depending on how bright/dark it will be outside when you capture footage.
Regardless of all of that, I was still uploading poo quality video even though the local rendered videos were crystal clear quality. It definitely seems to be a game of finding a good median between high bitrate and low file size.
No, I would definitely keep down converting your bitrate from 45Mbps to 30Mbps on your local files since you want to give your encoder as much data as possible to play with. If the quality looks good on the files that your editing software is spitting out after encoding, but looks like poo when you upload to YouTube, it's definitely YouTube's encoder screwing the pooch.so if I turn off protune on my 5 it'll drop to 30Mbs? My editing software will only render 1080p/60fps at a max of 30Mbs so this may be my issue, utilising protune my bitrate exceeds the ability of my editing software for MP4 files
