Microphone Wind noise problem
goncalecas
Hello guys, I'm new to these community and I need your help/opinions.
I want to start filming my rides properly with good image and audio quality of my bike's exhaust sound.
I bought a boya by-mm1 microphone ( recording attached to iPhone) and I tried it everywhere possible to try to record the sound, but I can't seem to get rid of the wind noise. I tried in the back of the bike, inside the seat, on my backpack/ jacket, with the dead cat on, everything... The recording is so bad I can't even ear the bike when I'm riding, it cancels the noise and reproduces a high pitch sound from the wind.
Could you share how you do it yourselves to get a cleaner sound of the exhaust? Do you think it is a bad microphone brand to record these type of things, do post-editing of the audio files help?
From what I read from different moto vloggers, zoom mics seem a better and usual choice. Are lav mics any good too?
I tried a lot of things but none of them seems to work, I would appreciate some help!
Thank you all in advance and safe rides! :)
In addition to motosera, wrapping a dictaphone/smartphone in foam or something similar and putting under the seat will capture exhaust audio brilliantly.
As for you mic issue, I would try a different mic or try connecting to a proper recording device and playing around with gain ect.
It's all trial and error with this motovlogging lark :)
Is the mic 100% compatible with your phone? Not all mic jaks are the same!
If just after engine noise, maybe get an audio recorder as @Pooley has suggested, or even an old actioncam, and put it under the passenger seat on top of a sponge and wedged under another to keep the wind away from the mics and stop the device rattling or touching the solid parts of the bike causing vibration
Thank you!!
It is compatible, I think it's just not a good mic ( shotgun mic) to record these type of things, I will try all of your suggestions! Thank you all for you help!
The Zoom is a good audio recorder, as is the Tascam DR-05. All my bike audio is normally recorded in helmet so I can talk too, but with a fruity exhaust it still comes through and cuts a lot of wind noise too. If you just want bike audio I suggest going the route @motosera and @Pooley have mentioned
I was surprised when I first tested my setup how I could actually hear the bike pretty well. I still have factory exhaust, so it's not really loud to begin with, but it still sounds pretty good.
I have a zoom audio recorder but obviously the built in mics are of no use for motovlogging - I presume some sort of mic that can be used in the helmet can be plugged in? ANy recommendation?
I had exactly this problem until I simply ran the microphone down the inside of my jacket and clipped it to the back of my trousers. Picks up the exhaust sounds fine without any wind noise. The problem I now have is how to do this with the camera mounted on the bike not on my helmet!
I have tried lots of lav mics and many were just too sensitive and my exhaust to loud so nothing was ever really usable or coherent when it came to narrating until I landed the purple panda mic. That mic along with its dead cat cover has worked pretty well for me in my last couple videos. I pair this with a used GoPro Hero4 I bought on ebay and it's been working out quite nice. I think one of the main things to consider is the sensitivity of the lav mic. You actually want a less sensitive mic so it picks up less wind noise. How this sensitivity is rated/measured I am still trying to figure out. I just know the Purple Panda hits that sweet spot of being sensitive enough to pick up my voice but not so sensitive that wind/engine/exhaust noise destroys everything.
I used the purple panda for a while, but still found it too noisy, I've recently switched to using an Interphone Prosound mic and it's by far the best I have used so far. That said I seem to have partially killed a mic adapter riding in the rain this last weekend. So I'm having other issues now!
However YMMV, there are so many variables - I get a lot of turbulence off the fairing of my bike at certain speeds which causes it's own issues.
Interesting! I'll have to check that one out. I wonder if its available in the USA the Interphone Prosound mic.
Hi Motosera,
Is this it?
YBG
