KruznW/Kev
So I recently bought an Ion Speed Pro 2nd generation because it has an external mic outlet. Due to the fact that its a 2.5mm jack and pretty much no one makes 2.5mm microphones I bought a 3.5mm mic with the drift hd 3.5mm -> 2.5mm adapter. PROBLEM - When I connect the mic to the camera the sound just gets completely muted (no sound at all). I tested the mic and it works, ive swapped out the adapter 3 times, and Ive tried plugging in the mic with the camera off and with it turned on. Ive called Ion but they were ZERO help and kept blaming the mic and/or the adapter. Am I missing something here or is the camera just F&€ked up? BTW - for cool pics around the Boston, MA area check out Kruznwithkev on Instagram!
