mrtommygunwhite
Trinith said:you're still getting the same quantity of gas per $ (my keyboard doesn't do pounds..)
here you go ££££££££££££££££££££££££ plus my keboards not racist so $$$$$$$$$$$$$$$$$$$$$$$$$$$
Neilisin said:I've run my DRZ (Daisy) from 80 upto 98 and I can happily say that it runs the same on all the above, in fact one notable remark is that it runs more economically on the lower the octane, as in increase MPG... it makes no sense at all.
Trinith said:Neilisin said:I've run my DRZ (Daisy) from 80 upto 98 and I can happily say that it runs the same on all the above, in fact one notable remark is that it runs more economically on the lower the octane, as in increase MPG... it makes no sense at all.
Actually it makes total sense once you know what octane actually does. It INHIBITS the burning of the fuel. Higher octane fuel is more stable and less likely to combust. That's why it's used in very high compression motors. Lower octane fuel will spontaneously combust once it's compressed to a certain point (which is related to the temp of the combustion chamber) which is where the knocking sound comes from when you use fuel with too little octane. Higher octane fuel, being more stable and less volatile, burns slower. Because it burns slower it (in a sense) puts out less energy inside the motor. The piston is not pushed as hard or as fast as it would be by lower octane fuel. So to do the same amount of work you have to use more of it, and that means less efficiency.
It's worth noting however that the difference is VERY small. I usually see a 3ish mpg difference between premium and regular. On a motorcycle where you're only using 4 gallons or so that's not a very big deal. But in a cage with a 15+ gallon tank, well...the difference in both price and distance capability becomes pretty noticeable.
Oh, one other thing. Running too low octane won't damage anything until you hear the knocking or pinging. If you don't hear it you're ok. There's only 2 real downsides to running too much octane, it costs more and it's less efficient. There IS a slight decrease in HP with higher octane, but you won't feel it.
sstimmyy said:Fuel may be much cheaper in the USA than here in the UK but im guessing the average US daily commute is done in a much bigger vehicle and covers a longer distance, stuff is much more spaced out it seems.
Trinith said:There IS a slight decrease in HP with higher octane, but you won't feel it.
DodgeRider26 said:You can all bloody sod off
DodgeRider26 said:Additionally, if you buy from a quality fuel supplier such as BP or QuikTrip here in Kansas City then you'll learn that their premium and standard grade fuels all have the same cleaner additives so buying Premium 91 octane just to get "better" gas is often a misconception.
Trinith said:DodgeRider26 said:Running excessive octane levels in your fuel can cause more engine deposits as the fuel isn't burned as completely, effectively making it a dirtier fuel. I never really thought about it that way, but it really makes a fair bit of sense to me.
NastyEvilNinja said:Trinith said:DodgeRider26 said:Running excessive octane levels in your fuel can cause more engine deposits as the fuel isn't burned as completely, effectively making it a dirtier fuel. I never really thought about it that way, but it really makes a fair bit of sense to me.
That's completely the wrong way around, though!
Higher octane = better combustion + less deposits.
If you want an extreme example look at aircraft or Formula One fuel! They ain't running 87 octane fuels, take my word for it!
Sh1ftyClutch said:Speaking of winter, what do you use to winterize your bike? Mine stands outside in a garage tent
