RoadcraftNottingham
Hey people,
I'm trying to edit my friend's Drift HD footage in Cyberlink Powerdirector 9. When I drag the file to be edited in the window it comes up with an "this media type is not supported, unsupported format or some other reason" error message. I've dragged other .MOV files over from other cameras without a problem and the files play on the computer. The only way I can get it to work is using a very long conversion process then dragging it over as another file type.
Has anyone had similar problems and how did you cure it?
Cheers.
Cheers.
