Aleks
I was riding my moped the other day but then it bogged down and wouldn't rev, and it sounded bubbly when it was idling. So I took the carb off and gave it a good clean, put it back on and it had the exact same problem. I then swapped the carb from another bike I had laying around, (same bike for spares), set it up and it worked for a bit. However, about 10 minutes of riding it bogged down again! I left it idling for a minute then I set off without an issue for about 5 mins, then the same thing happened again, so I left it idling again. I set of and it was fine but then bogged down after 2 mins and so on, and I had to limp it back home. This (I think) means the carb isn't filling up fast enough causing it to empty when accelerating, then filling back up while idling. Also, the carb isn't leaking.
Anyway, I was wondering if I could get some tips on what to do because I don't have much experience in this sort of stuff, and I don't want to start dismantling things without knowing what I'm doing and make it worse.
Thanks!
Thanks!
