30FPS vs 60FPS?
How much FPS do you use?
  • Total voters
    40
Ah, that's good to know. Does that feature insert additional frames in 30fps footage to make a fake 60fps by averaging the 2 real frames either side of the false frame?
As of yesterday YouTube supports 60fps for all videos, so get that frame rate up!
I'm not sure. Now that 60fps is supported I'll be trying it out soon enough. I just hope it doesn't make 30fps footage look jerky if it's mixed. Though I'm sure clevererererer minds than my own have dealt with these issues already!
It will look the same as your exported video. If you mix framerates then export, all your video will be at the same framerate.
You don't get variable framerate videos that switch between 30/60fps and how the 30fps scales up to 60 will depend on your rendering settings.
