Project bike pt6 (CG125): Indicators, grips & costs so far..
Re: Project bike pt6 (CG125): Indicators, grips & costs so f
Firstly, id like to just put it out their, that I HATE WIRING!!!!!
Friggin confusing at times.
The indicators- you got your common earth(good), the rear Ind. will help on the corrisponding color for front.(possibly Brown(left?) Green(right?). O/wise Read the manual?? lol
You may be connected to a pos wire, which will give you a light, but not be connected to Ind. Relay circuit. So no flash??
Nice patience btw, ive built a few bikes, taken stax of still shots, but never had the patience to film it.
Ill have to go 'n watch your whole build now.
Cheers
It Maybe your battery is too flat? happens on my little c90 . but I just rev the bike and it works lol
ALSO
Ive been 'meaning' to make one of these for the workshop. Perfect for cleaning engine fins and hard to get to places.
Very easy to make, wether you wanna search 'howto make' upto you, but youll see by that 2nd Vid, its a very simple science behind howit works.
http://www.youtube.com/watch?v=Fd8yqFJkn6A
http://www.youtube.com/watch?v=5vuENNhOMQs
Plus, your Grips, ifu cut the throttle tube to length itll fit. The edge on the Throttle tube that stops from sliding further, will be replaced by the grip itself, thatll prevent sliding up. BUT you have to make sure your switchblock/cable holder/assembly(r.h.side) is screwed tight. So as to help stop the grip end from rubbing internally on h/bar end.
Hope it helps your build.
Cheers
That's a shame about those grips!!!
Bike is looking good
Have you had the engine running yet?
Thanks for the tips. Ill wait til the engine is running so I have full alternator voltage then check the lights. Not had it running yet, should be attempted in the next few days so in the next upload.... I hope :)
