Moto Guzzi V7 | Removing the Transmission Box Assembly / Refitting Rear Wheel
Other than another video I made a couple of years ago I have not found many how to remove or replace the rear wheel on a Moto Guzzi V7. On my previous video I showed how to do so without removing the transmission box assembly, which is just about manageable with a standard 130 tyre. If however like me, you have a wider rear tyre, that way is not possible, and is a bit fiddly even with the standard sized tyre.
In this video I show how easy/hard it is to remove the transmission box assembly and refit the rear wheel. This also allows access to grease up the shaft bevel gear too.
I do suggest a soft mallet, and you will definitely want some Loctite as well.
