Ramblin'
Ramblin'Rider on YT
Thanks for the help y'all!
I started out with the cheap lapel mic that Do it With Dan recommended and it actually worked OK. There is a video where I go 82 mph on the highway and there was little wind noise. I did have to speak loudly to be heard but it worked. However, the mic adjusted somehow and I was getting horrible quality during my next rides and could not find that sweet spot again!
So, I upgraded to this Sony stereo mic http://amzn.com/B0058MJX4O and upgraded to real dead cats instead of the cheap foam that comes with the mics http://amzn.com/B00YQBCU5W . I spent about an hour (an entire gopro battery lol) before my ride today trying to get the placement right with the new setup. I thought I finally got it right but when I got home 6 hours later I had maybe an hour of usable footage without wind noise
It is weird, it seems to be fine sometimes at 45 mph and other times only fine at less than 15 mph. All the vents are closed yet it seems the cross wind is almost more an issue than the wind from speed. It almost seems to be amplified when the screen is closed for some reason too.
I am using a Shoei Hornet X2 http://www.shoei-helmets.com/Helmet.aspx?Hornet X2&h=25&t=2
Which has a really shallow chin area so if I place the mic there I end up eating the dead cat wind sock thing. So I have been placing it the only other place which doesn't give me a literal headache, between the helmet and the cheek pads on the right side (All the Sena wires and mic are on the left).
I have tried almost all the placement and angles possible and even put some thin foam craft sheets around the mic/deadcat and between the mic and helmet with no results.
The only other thing I have heard and haven't tried is buying a padded bra and cutting out the padding to put around where the mic is. My last option I guess would be too upgrade again to a "noise canceling mic' but I'm hesitating to spend more $.
I made a vlog about this same situation today at 30mph which I thought was a safe speed...I was wrong, all wind..
PLEASE, any and all advice is welcome! Even if it's just a hunch and you have not experienced this lol If I try the bra and it doesn't work I will be out of ideas that don't involve spending more $$ ..getting very very frustrated cause I know wind noise is one of the top thing that turns me off from watching
Thanks for reading and thanks for the help everyone!!
