Helmet Chin mount for camera ?
LandyVlad
King of Mycenae
I saw on one of the YT motovlogger channels - chaseontwo wheels? or maybe someone else.
It was a bracket which can be secured to the chin portion of the helmet - outside, under the vent - which allows for fitting of a gopro style mount.
At the time it was not available but was going to soon be available on the website of whatever company was concerned.
I know this is very limited info but perhaps someone recalls it?
It seems to me that it might work well for me with my Shoei Neotec 2 helmet.
I just used the curved GoPro mount and attached it to the most suitable curved section of my helmets chin area. For where the mount didn't take to the helmet correctly with the supplied 3M adhesive tape, I added Gorilla Glue to fill the void, then I covered all the edges with Gorilla Tape so wind resistance wouldn't build up at high speeds and add pressure.
Sounds extremely messy but its actually neat IRL! The tape tidies it up. Will take pics later when home from work if you wish! Just remember to allow for bracketry which enables you to tilt your GoPro upwards slightly, or else you will just end up with footage showing your fuel tank and handlebars, unless that is what you want! :)
John
Do you mean Ruroc Atlas \ Berserker mount?
:) Thanks. I'm pretty sure that the brand is indeed Ruroc but it wasn't the Berserker
I just used the curved GoPro mount ... Will take pics later when home from work if you wish!
Yes please, photos would be great.
:) Cheers mate that's a good range of mounts but none for the Shoei Neotec / Neotec 2.
Sadly their website states that:
This mount is NOT COMPATIBLE with any other helmets unless listed otherwise
and that appears on all listings.
Amazon has them. Actually they are pretty much the only kind I can find on Amazon now. I use one all the time. They work pretty good except the straps tend to come loose on a regular basis and you need to keep tightening them.
