MotoNordic
Moto Nordico
MotoVlogers what’s up!?
So I’m interested in knowing what your current workflow look like while editing your vlogs?
How has it changed since you started out?
I usually go this route:
(Editing in Final Cut Pro)
1. Import video- and audio files to a dedicated folder for that particular vlog on my computer, import them to a pre saved project with correct resolution and FPS + language.
(I vlog in English, Swedish & Spanish and have one project for each language containing the outro in the current language. I usually leave the project as is when exported and uploaded to YouTube and next time I’m gonna edit a vlog in the same language I remove the previous clips.)
2. Sync audio with video file inside FCPX, then I add the clips to the magnetic time line
3. Add some brightness, compressor and a limiter to the audio
4. Color Grade all clips
5. Start watching from the beginning and cutting out unnecessary content until satisfied
6. If I mention something in the video and want to show maybe a picture or a small clip I insert them also in this phase
7. Apply audio fades between every cut to minimize audio “pops”
8. Look through the whole video, if all OK I either upload directly to YouTube through FCPX or export the master file and upload it. The only “advantage” to first export and then upload is that I can start edit the title, description, tags etc. a little bit sooner and change it how I want during the upload since the video appears at once at YouTube.
What’s your work flow, any thoughts about mine?
Cheers!
Cheers!
