Rant Bike Problems
I've had my Daytona for about 5 years and have had a lot of issues. Started on DAY 1 with the stator and rectifier. Then another stator, then the CPS. Since I replaced all of them a few times I have not had an issue but also the connector between the stator and the bike tend to short out and cause issues like this also.
Good luck man. Triumph's are a pain but also the greatest bikes EVER..
I can't find the problem and neither can my mechanic :( redone front wiring as there was a few splits and cut cables.. Rebuilt the fuel pump, new battery, disconnected the alarm system.. It all seems fixed after then it goes bad either the same day or the next. After the fuel pump I got a week of use from it and it did this above ^ literally lost all power without the engine cutting out this time round
Check the rectifier and stator. Those two caused the most issues with my bike.
Bummer :(
You mentioned the smell of fuel. I guess you checked fuel lines and filter are clear?
I did look at the fuel lines couldn't see any build up/ air bubbles, not checked the filter but i did mentioned it to the mechanic and he said it shouldn't be the problem.. who knows!
That could be the other issue. I had taken my tank off once and kinked the fuel line.
These Triumphs sure seem to be troublesome !
