I feel the same way and I really don't like the way the extreme fish eye looks for vlogs.Superview is a gimmick that compresses the video vertically. It just breaks the aspect ratio.
yay to the new start SAME HEREim just starting out so im using 30fps because i only have a 16gb card and i dont have a mic yet
While I shoot nearly everything in 720 @ 60 FPS, you've got to weigh a lot of different factors when choosing what settings to use when filming. I'm a HUGE cheapskate, so I'm not gonna buy a newer camera, and I use a GoPro Hero HD (the original), so I've don't have as many options as those who have a newer camera, but the same basic principles apply.
Shooting at higher vid quality means more battery drain and more space taken up on memory cards/ hard drive. Considering the fact that I get about 1 min per hour of useable footage, this is a major factor for me. Next is the FPS...Shooting at 30 FPS allows more light into the shutter giving better results in low light conditions, which isn't a big deal for those in California, Hawaii, Arizona, or anywhere with lots of sunlight and very few shadows. Those of us who film in areas with lots of shadows/ low light may end up with very dark or unusable footage is we are shooting in 60 fps and low light. This is something that I've had to learn the hard way.
I typically render everything at 720P and 30 FPS for youtube anyway, so there's no real reason not to shoot that way to decrease the raw footage editing in the end. That being said, as I stated earlier, I typically shoot in 720/ 60 so I can slow things down. If it's raining or low light, I shoot in 1080/30 so I can zoom if I need to.
I hope this helps, but I doubt that it will. If you want to see examples of my work, look at my youtube page (Mustache Assault Cycle). everide also shoots in 720/60 and he's got a TON of followers. If it works for him, there's no reason why you can't get youtube famous doing the same.
Huh? Never thought of it that waySuperview is actually pretty neccesary for dirtbiking as there is a lot more head movement than on the road and because your sitting more upright it's hard to get the bike in frame without angling the camera at the ground, and then it's just annoying because your eyes always want to look up when watching the video. I know it's just dynamically stretching the video but it saves the trouble of doing it manually
Also I suppose the fisheye effect would be worse riding around town but for when your riding offroad it's awesome.
I filmed my latest 2 vlogs in 60fps and I definitely won't be going back to 30.
Fluidity of motion, clarity and lack of blurring etc.Why what was so much better about it?
Maybe you don't have the proper wide-angle lens. Think about it. To get more of the scene around you into the frame you need a wider angle. The camera is handling the angle of the lens by choosing what part of the sensor to use for the video. Instead of using the full sensor area, it is cropping it or skipping pixels and averaging to give the illusion of a wider or narrower lens. It is all done in software and your camera calls that "Superview".Superview is actually pretty neccesary for dirtbiking as there is a lot more head movement than on the road and because your sitting more upright it's hard to get the bike in frame without angling the camera at the ground.
For fast moving action I don't think I could stomach using 30fps after seeing the glory of 60.
30fps will be fine for panoramas etc, but 720p60 is far better than 1080p30 imo for the motion in moto vlogs.
Nope, it's not that.If you get blurring, check your encoder/video editor settings. There shouldn't be any. Make sure "frame blending" or anything that sounds like that is NOT selected.
