Wind Noise -- Need Ideas
Leaky
6
6
2003 CBR F4I
Getting too much wind noise through mic. Now I have a cheap helmet and cheap SJCAM camera.... so I know this needs to improve. I also have a "dead cat" over the mic.
The mic is positioned just to the right but inside front of the helmet.
I was thinking of pasting some more of that dead cat material along the front inside of the helmet wall. Would this be a good idea or do you guys and gals have any helpful tips or solutions that worked for you?
Thank you
2,218
Thank you
On a couple of my helmets I took a bit of cotton ball and put over the mic to deaden some of the wind. Then I have the black foam over that as well.
I use this on my half helmet and the modular. I also ride with batwing fairing on the bike so your results may vary.
scooterwuf
828
631
Philadelphia/South Jersey
Kymco Downtown 300i
If you can set your mic recording to different levels don't use the highest. I use the middle setting, and later in post I use compression and normalization.
If you have anything other than a full face helmet you may always have some level of wind noise, but as R-Rated suggested there are tips for lessening and even eliminating them. Do test with different positions and windscreen material.
- Wolf
3,676
I lined the bottom of my chin piece with deadcat fur on my other helmet, it works well but it can be irritating if you don't trim it.
SighBored
@thesighbored
Jan 18, 2015
2,521
1,024
Malaysia
www.thesighbored.com
2012 Kawasaki ZX-6R
It's a lot of trial and error to see which works out, try to make single changes each time so you can know if you are doing something right and continue in that direction instead of multiple changes and not sure which is the correct way to go.
On a lighter note, if you ride in space, you won't have that problem since space is a vacuum. Ha-ha!
Reactions: Leaky and R-Rated
LoneWolfer
Lone Wolfer Garage
Jun 1, 2017
503
656
Connecticut
www.thelonwolfer.com
Leaky - is the mic attached to the actual inderior wall of the helmet, or the cheek pad? I found that having the mic in contact with the shell of the helmet, even the lining on the inside, causes issues with sound including picking up the wind noise hitting the shell of th helmet.
If you can actually put the mic inside the cheek pad, great, if not then having the mic attached to the cheek pad so that it isn't touching the interior of the helmet shell can get you positive results.
Theodor
Don't wannabe
Nov 16, 2017
310
297
Estonia
Valkyrie 1500
If the helmet itself causes noise, mic is bound to pick it up. If mic is omnidirectional, i'd try taping over the outward pointing parts of the microphones housing, under the deadcat.
Chin curtain may also be of help.
Leaky
6
6
2003 CBR F4I
The mic is just kinda floating, but is close to the wall of the helmet. Will try something different if I get out
Reactions: LoneWolfer
Leaky
6
6
2003 CBR F4I
Thanks. Was thinking of adding more dead cat a
2,218
I like the dead cat idea but unfortunately sometimes there needs to be too much fur for a limited space. You should experiment with different materials and record with each for comparison.
