Phone & Camera Combination.
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
Hi All
New here and new too MotoVlogging.
I have a quick question for those in the know. Does anyone use a mobile phone to capture the audio and camera for video and merge it during editing?
If so how do you find this method? or would you recommended a dedicated sound recorder?
Note: Camera with Mic input is on list of kit when funds allow :)
Cheers
OCDB
Drakhen99
Aug 31, 2020
849
773
road-reality.com
Hi All
Cheers
OCDB
What camera are you using? Even if it records its own audio, that can be used to sync up the audio-only recording with the camera's A/V recording.
Most editors will allow you to move things around on a timeline, which would allow you to line up the files. If you did a clap or three at the start of your video, both where the mic will pick up the sound and the camera will pick up your hands, you should be able to get very close to in sync on the audio and video.
Your phone will work as a recorder, but you'll probably get better audio with a dedicated recorder like a Tascam or Zoom. Someone more knowledgeable will be in soon to better help you, but it CAN be done the way I outlined.
Reactions: Hakz and HippoDrone
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
Solid advice, just the kind of thing I am after. As for the camera(s) I have a old GoPro (possibly Hero2) & a cheap Victure 4k cam (just for messing around with, nothing special) and these have built in mic's so the thinking behind external audio capture is to get rid of the horrific wind noise the built in camera mics will capture. Hope this makes sense.
I will try the clap method for sure though.
Cheers
Dan
Alex2wheel
33
30
Peterborough, UK
Kawasaki Z900
Hi All
Cheers
OCDB
When I started doing videos a long time ago, business-related videos, not motovlogging, I used to have the Rode SmartLav+ mic and record directly into the phone. No problem at all trying that if you are on a budget.
However, an external recorder would be more convenient, ideal, because with a phone someone might call you, or you might receive some sort of notification from an app, which might then interfere with your recording or you might want to use your phone for something else like GPS.
Regardless of which option you go ..yes, you should be able to sync the audio in post. As others have mentioned, you can try clapping a few times, I also like beeping 2-3 times, as these tend to create bigger spikes in the audio waveform.
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
Cheers All
Much appreciated feedback.
@Alex2wheel good point on calls and app notifications disrupting audio capture.
I will likely put my phone in DnD when I test this.
Cheers
Dan
Theodor
Don't wannabe
Nov 16, 2017
507
559
Estonia
Valkyrie 1500
If budget is concern, you can definitely go with recording the audio with phone. As long as you get an app, that has manual gain adjustment (you might need to cough up 5-10 usd for that one), and you can use a wired mic, the solution will have sufficient quality, not to justify the extra expense and hassle, of purchasing dedicated audio recorder.
I have used even the original headset mic, strapped on my back, to record the bikes sound, while riding, and it did not seem bad at all.
Drakhen99
Aug 31, 2020
849
773
road-reality.com
Haha, I should post a test clip of me starting a ride... walking around the bike firing up all the cameras, then again to start recording [I like to give 'em each a few seconds to wake up], and then standing somewhere all the cameras can see my hands, and then clapping.
Then I get on the bike and ride!
  • Haha
Reactions: Theodor
Drakhen99
Aug 31, 2020
849
773
road-reality.com
I think the app I downloaded on Android was Parrot, and it was free. It allowed for gain adjustments and things, but had limitations elsewhere. I'd expound upon that, but it's been so long since I used it that I forget now.
Theodor
Don't wannabe
Nov 16, 2017
507
559
Estonia
Valkyrie 1500
That could be a sight... :D
Reactions: Drakhen99
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
Haha that must be a sight indeed.
As for strapping the mic to your back never thought of that, I assumed a pocket or under the seat would be my best options, but every day is a school day.
Theodor
Don't wannabe
Nov 16, 2017
507
559
Estonia
Valkyrie 1500
I did try under the seat also, but my bikes frame picks up wind whistling around there, at some speeds, so that was not the best solution in my case. Strapping on the back was easy, because I use chesty, for my camera. Also, no wires would get ripped, if I step off the bike, and forget I was recording :p
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
I may try this method, as I use a chesty as well.
Cheers
Drakhen99
Aug 31, 2020
849
773
road-reality.com
I think if I used a chesty, all you'd see is my bike's dash, and not much else! I have one though, I may have to do a test LOL.
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
My previous failed attempt at making a video, the view from the chesty wasnt bad, as the MT09 is a very upright seating position and I only have the Puig Sports screen, so it sit's inline with the dash.
No just to master the audio.
Theodor
Don't wannabe
Nov 16, 2017
507
559
Estonia
Valkyrie 1500
I put the camera on, with double hinges. one I tightened with a screwdriver, that determines the recording angle, when camera case is touching the backplate. The other one is fingertight, so I can unscrew and drop the case down, to open the rear door and take camera out. And then to put it back to the previously set position, I just close the door and put the case back all the way, touching the backplate and tighten by finger. I found this to be the easiest way to get almost the same angle every time. Clothes still have some effect, but overall it is more consistent.
OCD_Biker
@theanxiousbiker
Apr 29, 2021
22
26
13
Yamaha MT-09
My only concern with a chesty is long term, will all video footage look too static. As with a chin mount you get more rider movement in and out of the bends etc.
Obviously this is not a massive concern at the moment as the one and only video I have created has been scrapped due to terrible audio.
Theodor
Don't wannabe
Nov 16, 2017
507
559
Estonia
Valkyrie 1500
My concern was exactly the opposite. At the time I decided to start filming my rides, I had seen too many videos from cameras attached to helmets, that happened to be on very restless heads, and I found it tiring to see the picture going left and right and up and down all the time, with jerky movements. While riding, you need to watch all around, so eliminating head movement was not an option, so I chose the next best thing.
Drakhen99
Aug 31, 2020
849
773
road-reality.com
Funny you should mention "restless heads" ... I use the highest or second-highest stabilization setting on my GoPros to negate the quick movements you get from keeping your head on a swivel. And that was one thing a normie friend of mine told me he liked about my videos, that they were smooth, as he called it.
Reactions: Theodor
