Nanocam Pro???
GNVlogger
hey i don't have a very big budget to spend on a camera but i need something better than what i am using, i was looking at the nanocam pro, http://nanocampro.com/ ,and i was wondering wether it would be any good, i have found it for $190 (nz), and i can really only spend $200 on a camera, does anyone know if this camera is any good or if i can get a better one for that price?.
check this out if you want to see what i am currently using: http://m.youtube.com/channel/UCLRb3Sb8Xhq5iJLdhvlGwdA
Could be ok.... An obvious GoPro clone ... Chinese backing I think? ... Uses class 4 SD cards ... So maybe older tech inside?
But if that's your budget then that's your budget! ... You could probably get a second hand or older model rig of the big names for similar dollars...?
As Shirou on hp this site has mentioned quite a number of times.... A lot of the basic tech is all so similar in all the cameras now.... So long as you use this particular one inside it's advertised/claimed limits then it will likely be fine!
thanks man that's a real help, thanks
