Loctite vs Grease?
LoneWolfer
Lone Wolfer Garage
Jun 1, 2017
745
1,101
Connecticut
www.thelonewolfer.com
Loctite, or thread locker because I typically use the brand Permatex, is for helping keep a bolt or nut exactly where you want it until you want/need to remove it with a little extra force. I am well aquainted with doing this because I ride a Sportster and they have a tendency to rattle off any and every nut and bolt they have.
On the other hand I don't use grease to do the opposite, I use Anti Seize. Loctite makes a version of this product as well, but again I use the Permatex brand. Anti Seize makes it so you can easily remove a bolt that has been in place for long periods of time, in an environment where rust is unavoidable, or in places of high heat which can cause metals to bond/expand/retract and all other manner of annoying things that will make the bolt or nut difficult to remove without a little lubrication.
Grease is really more for an area or mechanism that moves such as joints or bearings. It can also be used to slide parts into place but again there are other products such as WD40 I would rather use than grease. I also sometimes use grease to hold a gasket in place if there aren't guide notches to do that job.
lupin
2016 Solar Bear Champion.
Jul 5, 2015
2,257
1,449
Australia
www.imlupz.com
FZ1N
Its a interesting quandary.
Back in the olden days when I was an apprentice, it was common to use oil or grease on a bolt to allow it to be tightened to the correct torque. Head bolts are a perfect example.
However loctite (or similar products) now not only act as a locking solution, but also allow the lubrication why they are wet.
About the only bolts that get oiled now are head bolts, and some axle nuts.
