It does not look as if the sticky mount would be able to fit on the direct front of your helmet because of the chin vent being so large. You could try and be ingenuitive and figure something out though maybe...no idea what. It looks like your easiest mounting place on your helmet for motovlogging is on the side of your helmet or the top of your helmet, but you'll look like a teletubby.
Actually...if you want, you could probably mount the sticky mount just off center of the very front of your helmet and then use the various elbow curves or whatever and be able to direct the camera to the front part of your helmet that you want. Takes some creativity, but I believe RebelYell91 does something similar to that.
