I’m going to Spain in about two weeks to do a tour of the Pyrenees with buddies. Most of us will be riding the S1000XR through the 30,000 mountain corners over 9 days. A few of my buddies and I will be doing video for the trip. To this end, I decided to test several camera gear setups on the XR.
This video is just a gear setup test. Its only intent is to test various mounts, cameras and reframes. I mounted an Insta360 One X2 on my friend's BMW S1000XR and put a GoPro Hero 9 on my helmet (chin mount). Both cameras have mics attached into my helmet.
Suggestions are welcome. Maybe this will help others.
Here are the setup details:
1. Insta360 One X2
Please forgive the insipid narration. I just kept talking about mostly nothing to give a continual test of the audio at different speeds.
1. Insta360 One X2
- Attached to the left mirror via
- RAM Mount Clamp into ball mount
- RAM Mount double-socket arm
- Insta360 Vibration Damper (keeps camera from vibrating apart internally)
- Attached to the One X2 is the audio adapter (snugly kept with a rubber band)
- A long mic cable goes to the Purple Panda mic, which is within a dead cat and placed within the helmet atop the chin curtain.
- Normally a USB cable goes into the audio adapter to keep the Insta360 One X2 charged - no battery drain - from the USB ports in the fairing or phone holder. I didn't bother for this short test.
- RiderTechMoto custom mount for the Shoei X-14 that attached a GoPro buckle mount
- A J-Hook GoPro mount attaches to the buckle
- A curved extender arm provides a wide range of angles for the camera. When used on my S1000RR, it is oriented more upward because the helmet points downward in a crouch sportbike position. On the XR, it is oriented more level for the more upright seating position.
- The GoPro is within the Media Mod to provide the analog 3.5mm mic input
- The mic is a Sony ECMLV1 within a dead cat and attached beneath the padding near the mouth/cheek area.
