Footpeg Vibrations And How Can I Reduce Them?
WingManGT
216
148
Varna, Bulgaria
www.facebook.com
2004 Kawasaki ZX-6r
I've just returned from a 500km trip and the vibrations in the footpegs are killing me. My feet just go number after the first 100-150 kilometers. Is there any way I can install rubber bushings or something to alleviate that issue?
Any help will be appreciated.
p.s. Bike is a 2004 Zx6r
Have Fun!
1,949
Clarksville to Nashville, TN
If you don't have rubber on the pegs already, you can try some that do.
The idea about the rubber bushing has some merit. However putting a rubber washer in the mount might not stay tight. You could check you engine, swing arm, and exhaust mounts. If any of them have bushings and one is worn out or loose it could allow a vibration to telegraph throughout.
Finally, try different footwear. I have some boots that are more sensitive to vibrations than others and my bike has rubber on its floorboards.
Surely there are some other ideas...
WheelyPerd
Everywhere @WheeliePerd
May 18, 2017
374
341
South Africa
Triumph Tiger 800 XCx
Sucks that your feet go numb so quickly dude, its small but have you tried changing your foots position on the foot peg?
My Kawasaki Versys' engine mounts all had rubber washers, to reduce vibration. Also had rubber washers where the foot pegs connect to the bike.
Another interesting idea from my Hypermotard: The top of the foot peg is rubber, so the actual foot peg is metal, but the part where your foot touches is rubber.
burlyjack
Oct 10, 2015
348
231
Oklahoma, USA
2004 Honda VTX 1300
Is it a new symptom just popping up? Rubber mounts could help. Other than that there's not much to do other than changing riding position and your riding gear. That is quite the distance to cover by bike for most people.
WingManGT
216
148
Varna, Bulgaria
www.facebook.com
2004 Kawasaki ZX-6r
I didn't have any other issues. I expected my back ti give in due to it being a sportbike, but vibrations turned out to be issue. Its not a new problem , just couldn't notice it before due to the short riding distances. I'll try to figure out some rubber inserts for the pins of the footpegs. that may help a bit.
SighBored
@thesighbored
Jan 18, 2015
2,414
933
Malaysia
www.thesighbored.com
2012 Kawasaki ZX-6R
I know what you mean. Been there, felt that. Numb foot is no where as crappy as numb fingers/palm. I'm not so sure that changing the pegs to ones which have rubber lining will help that much, you can try that. In the meantime, the other workaround is to move your feet, switch the position of your foot resting on the peg from time to time, give your legs a stretch while on the bike, or plan stops to rest / get off the bike, especially while getting fuel. Perhaps some thicker socks or boots with a thicker sole.
Reactions: WingManGT
WheelyPerd
May 18, 2017
374
341
South Africa
You could also try riding with "hiking socks" or "climbing socks", get them from any sort of climbing / hiking shop. They pretty thick, so should dampen some of the vibration.
