Audio Setup
TimMoto
8
13
Netherlands
Suzuki SV650S
Hi guys,
Since including me I feel like a lot of people are trying to find a good audio solution, so I'll post mine here.
Most of us dont want to spend a lot of money on a dedicated audio recorder and for people without a gopro an external mic is not really an option.
Nowadays most riders have a sena or something similar. So this would a be a good way to record audio, was my logic.
Since the sena has an ope mic to use stuff like assistant on android, its also possible to record it.
I'm using an app called wavstudio and the sound quality is pretty decent.
Just conenct your phone to the com-system via bluetooth and it should work.
Ill upload a video with it upcoming week so you guys can voice your opinion!
Laters
7,086
I hope your audio solution works out, I don't have a Sena or similar so have to go with the horrid GoPro mic adaptor.
lupin
2016 Solar Bear Champion.
Jul 5, 2015
2,256
1,443
Australia
www.imlupz.com
FZ1N
Audio is mostly about the microphone quality and placement.
Unfortunately I don't think you will get that good of audio from the sena setup as the mic is really designed to only pick up your voice and then the sena does it magic with it.
But like everything you have nothing to loose and its well worth a try.
SM26
Supermoto isn't just a bike, it's a way of life
Oct 29, 2015
117
100
Israel
Husqvarna 701SM 2018
Just to make sure, you are talking about this?
WaveEditor
I've tried a bunch of apps, but none of them was able to record from a BT headset.
in the end, I found that recording sound from a website and not from app is a much simpler solution:
https://online-voice-recorder.com/
SM26
Oct 29, 2015
117
100
Israel
Yeah thats the app for androis. Your com set does need to have an open mic though
I'm using a Sena 10C
how do I set an open mic though?
Google Assistant works fine, but only when I press the button, it doesn't always listens (and that's good IMO)
